Activity › Forums › Maxon Cinema 4D › Cinema 4D Delayed Animation On Attached Objects
  • Kouraib Abdmalek
    January 30, 2024 at 9:14 am
    Hi Joe,
    I think that when using the Shift Priority tag, you should also rearrange the objects in the Object Manager. This may fix the delay problem because Cinema 4D scans the objects from top to bottom. You can also get information that may be useful to you about the priority by right-clicking on Priority and then Show Help.
    I hope this is useful to you.
