Activity Forums Maxon Cinema 4D Cinema 4d Curve Editor Frame Rate…Problem
  • Cinema 4d Curve Editor Frame Rate…Problem
    Posted by Michael Gibson on February 11, 2010 at 7:31 pm
    I some how changed the frame rate in the curve editor to show in the hundredths, which is very irritating because my key frames are not falling on whole values. I searched in the help and online but cannot find the option to turn this off. This happens when scrubbing in the curve editor time line… an example would be between frame 1 and 2 you can select 1.01 – 1.99. Thanks for any help.
    Rian Helmhout replied 16 years, 6 months ago 2 Members · 1 Reply
  • Rian Helmhout
    February 18, 2010 at 5:22 am
    Hi Michael,
    Can you check out the preferences panel, click on ‘units’ and maybe your animation unit is at seconds but should be at ‘frames’.
    Hope this is helpful!
    ilimitado 3D Graphics
    https://www.ilimitado.info
