Activity Forums Maxon Cinema 4D Cinema 4D and Syntheyes workflow
  • Cinema 4D and Syntheyes workflow
    Posted by Joel Hebert on January 23, 2010 at 10:55 pm
    Here is my scenario.
    I’ve tracked a camera and an object seperately in Syntheyes (similar
    setup to the this tutorial…https://ssontech.com/content/boxmatch.htm)
    Problem is, once I’m in Cinema4D, I can’t seem to import that mesh
    sequence. It only gives me an animation sequence of the trackers paths
    of the Syntheyes tracked object (a null object)? I can import the mesh
    as an obj. but its motion path is not animated? Tech support told me I need to parent the imported mesh onto the tracking points in C4D. However, this has given me some rather strange results. I’m pretty confident I tracked the shot well so I’m assuming this is an issue with the way I’m working with the file in C4D.
    SO…..Could someone please share the proper workflow for Syntheyes to C4D with a shot with a moving object and a moving camera?
    Any help would be greatly appreciated,
    Joel H.
    Joel Hebert replied 16 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
