Activity Forums Maxon Cinema 4D Cinema 4D – After effects object buffer not allighing with screen
  • Cinema 4D – After effects object buffer not allighing with screen
    Posted by Andrew Wagstaff on October 4, 2012 at 11:46 am
    I am working on a scene that has a lot of video screens and when i try to use the object buffer method this is what happens
    I have a composting tag with an object buffer for both screens as well as an external tag with the size set to the screen and set to solid
    What am i doing wrong that makes the buffer solid not align with the screen
    Any help would be great
    Andrew
    Andrew Wagstaff replied 13 years, 11 months ago 3 Members · 3 Replies
  • Kevin Camin
    October 5, 2012 at 5:16 pm
    Just had this problem.
    Of course you can rotate your 3D nulls into position in AE, but I bet when you do that there will be drift; your 3D null won’t stay where it should and your image will slide around.
    I think there is a bug in C4D. You need to align your planes to a +Z orientation in the parameter settings. Then you can rotate them into whatever orientation you need. This should fix everything.
    Best regards,
    Kevin Camin
  • Darby Edelen
    October 5, 2012 at 7:35 pm
    [Kevin Camin] “I think there is a bug in C4D. You need to align your planes to a +Z orientation in the parameter settings. Then you can rotate them into whatever orientation you need. This should fix everything.”
    It’s been a while since I’ve used the External Compositing tag, but I believe Kevin is right.
    Essentially AE will only see the Axis data of the object that you’ve applied the External Compositing tag to. Since solids in After Effects always face down their Z-axis Kevin’s suggestion for using a Z+ orientation will work for primitive planes.
    If you’re working with a polygon object you’ll want to rotate the Axis (Enable Axis modification, then use the rotate tool) to match the orientation that After Effects will force on the imported solid/null.
    As a fix for your current setup in After Effecs you can duplicate the solids that AE imported, parent the duplicates to the original imports, remove all keyframes from the duplicates and then rotate them 90° on either the X or Y axis (the axis you need to rotate on may vary). Hopefully that will work 🙂
    Darby Edelen
  • Andrew Wagstaff
    October 8, 2012 at 9:14 pm
    Thanks guys i got it sorted
    all i had to do was rotate the H rotation of the objects to 0 for some reason it was set to -90
