Activity › Forums › Maxon Cinema 4D › Cinema 4D (aec) Opening in After Effects (why is there only Color-bars and no Video)
  • Cinema 4D (aec) Opening in After Effects (why is there only Color-bars and no Video)
    Posted by Romeo Meier on September 19, 2009 at 8:47 am
    I have a problem with After Effects, I just finally got the plugin so that i can Import the cinema 4D project (aec) into after effects so far so good but now when i import an Animation then i get to see color-bars only (the import works with still images thou) now i think i must do something wrong in the settings, in order for you guys to understand my situation i created this link with about 7 screenshots of After Effects, Cinema 4D and its settings please check it out: https://hollywoodlover2000.webs.com/exportproblem/ProblemwithExportingCinema4DProject.htm
    Please explain very detailed i’m new to this
    Romeo
    David Cabestany replied 17 years ago 3 Members · 4 Replies
  • Tim Shetz
    September 19, 2009 at 9:33 pm
    It would appear that After Effects can’t find the nochmals_trans.mov
    In After Effects you can right click on the missing footage (in the project pane) and select replace footage and find it on your system.
    Once you find it, I would suggest doing a File>Collect Files so everything gets moved into a folder.
  • Romeo Meier
    September 20, 2009 at 5:25 pm
    do i have to export the footage separeted from cinema or how do you do that i mean i realized that it says missing path but i thought that if i export it then it should export everything with it which is needed. I would be happy if you could explain how you would export from cinema and what settings you use
    thanks for the info so far
    Romeo
  • Romeo Meier
    September 21, 2009 at 9:27 am
    well where do i find that mov i mean i’m not making a mov i’m saving it as a “aec” and i don’t know where cinema the mov puts, please explain specificly i’m new to cinema and i need to know.
    I’m working only on test projects i can delete it and just start a new one then i would make a spining cube now what do i have to do next in order to get it into after effects correctly please explain it very detailed i want a step by step instructions on how to do that
    Just explain how to do it from the scratch i don’t know how to export aec file correctly please explain it 5 stpes at least
    what settings do i need?
    how do i do this so that mov will be exported with it ?
    why is there no tutorial or videotutorial about this?
    Romeo
  • David Cabestany
    September 27, 2009 at 8:50 am
    From looking at your screenshots it seems that the name of your main file and the passes is the same, if that\’s the case then the pass image is overwriting your main footage and AE is unable to find it because it is non existent.
    Try naming your passes with a word before, \”passes_whatever\” and see if this time you get the mov file.
    The twirly in your multipass options tab is closed, are you sure you need to render extra passes? Perhaps only rendering the mov file would suffice.
