Activity Forums Maxon Cinema 4D Cinema 4D 11.5 .SD plugin export issue.
  • Cinema 4D 11.5 .SD plugin export issue.
    Posted by Javier Lopez on July 3, 2010 at 8:41 pm
    Hello gentleman,
    I had encounter a problem, after applying the extrude nurbs to an object, making it editable and applying triangulate in Cinema 4D 11.5, when I use the export .sd plugin I can see 3 different elements, the .sd file exports fine, but when importing from Realflow 5 it recognizes 3 different elements that when imported don’t sit on the plane, but far above, and it’s impossible to center them.
    I had attached to image files with the results, hopefully someone can provide guidance on how to set them properly. Please view the screen capture on the link ahead.
    Thanks.
    886_c4d.jpg.zip
    Javier Lopez replied 16 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
