Activity Forums VEGAS Pro Cineform Render 9.0a 64bit
  • Cineform Render 9.0a 64bit
    Posted by Mark Moss on August 26, 2009 at 5:09 am
    I just purchased the Cineform Neo Scene to help me with my AVCHD files from the Panasonic HMC150. When I render the files, to the Cineform AVI, they have no audio. I load them into Vegas, and only the video track shows up…..no audio at all. I know I have the latest version of Cineform, so do you think this is a Vegas problem or a Cineform problem?
    Any ideas on what to do?
    Thank you
    John Rofrano replied 17 years ago 2 Members · 3 Replies
  • John Rofrano
    August 26, 2009 at 11:25 am
    I have read that CineForm doesn’t supply an AC3 codec and uses whatever encoder is on your system. Perhaps this is part of the problem? Also there were a lot of issues with 64-bit encoding not working properly. I stayed at Neo Scene version 1.3.5 because of this. If you have a different version that may be the problem.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Mark Moss
    August 26, 2009 at 5:01 pm
    My version is definitely newer. I just bought it. Do you think that I can get an older version from them….I can’t seem to find an older version on their website.
    Does the older version work well with the 64bit?
    Thanks for your help.
    Mark Moss
    Mossman Productions
  • John Rofrano
    August 27, 2009 at 11:27 am
    I am shocked because several of us tested the new version and reported to CineaForm that it did NOT work with Vegas 64-bit and yet they continue to give it to customers.
    Here is a link to the last known copy of Neo Scene to work with Vegas Pro 9.0 64-bit:
    NeoSceneV135b120-090723.zip
    Keep a copy in a safe place until they fix it.
    ~jr
