Activity Forums Adobe Premiere Pro Cineform Quality settings
  • Cineform Quality settings
    Posted by Bryce Douglass on March 18, 2018 at 1:39 am
    Hello, what quality setting should I use for cineform? my native footage is avchd. I know I could edit native but I’ve tried and I don’t like how avchd has the clips in a folder structure and I’d like to transcode and rename the files. Also learned the hard way if you rename the avchd .mts clips it messes up the media.
    I’ve heard 3 setting in cineform is high quality and it is supposedly required for DVD but I tried 2 setting for medium and it looked almost identical. Can I use medium quality setting to DVD as well?
    Also, what does cineform.com mean when it says filmscan 2 quality is for rigorous post? How do you define what that is? If I’m cropping scaling, color grading, using green screen chorma key etc is that rigorous post? Should I just use the highest quality since I have the storage space and not worry if I’m doing what’s classfied as rigorous post?
    Bryce
    Bryce
    Bryce Douglass replied 7 years, 8 months ago 4 Members · 7 Replies
  • 7 Replies
  • Ann Bens
    March 18, 2018 at 2:52 pm
    Cineform YUV 10 bit will do just fine.
    If you are using Encore for dvd export out of Premiere as mpeg2-dvd.
    Adobe Certified Expert Premiere Pro CS2/CS6/CC
    Adobe Community Professional
  • Bryce Douglass
    March 18, 2018 at 3:56 pm
    Yes but what quality? There is 5 4 3 2 and 1. 5 and 4 is filmscan and 3 is high etc
    Bryce
  • Ole Kristiansen
    March 18, 2018 at 5:19 pm
    High is just fine ! Filmscan 1 and 2 will put a lot of stress on your computer / cpu and your footage will not gain anything i quality !
  • Bryce Douglass
    March 18, 2018 at 5:35 pm
    okay thanks,
    What about say for instance I do lots of scaling. I often will be editing chroma key green screen and scaling different objects etc from video. Should I use filmscan then?
    Bryce
  • Ole Kristiansen
    March 18, 2018 at 5:54 pm
    If your footage come from avchd – then no !
  • Chris Wright
    March 21, 2018 at 9:56 am
    I do know bad things happen if you transcode half sampling down to 4:2:2 instead of 4:4:4. You’re losing half your chroma information in the transcode. you visually won’t see it, but your keying plugin will.
    https://cineform.com/444-vs-422
    also, if you do any gamma changes, you need to export to a 10 bit codec as seen here.
    https://cineform.com/10-bit-vs-8-bit
  • Bryce Douglass
    January 2, 2019 at 3:09 pm
    [Ole Kristiansen] “If your footage come from avchd – then no !”
    Well this is interesting. After several tests quality 4 is better than quality 3 with avchd. I transcoded two tests for quality 3 and 4 and imported them in premiere. I then put each cineform file above the avchd file and changed the program monitor window to 100 percent view and turned on and off the track view for the cineform file. quality 3 was blurry vs the avchd file while quality 4 was the same as the avchd file
    Bryce
