Activity › Forums › Adobe After Effects › Cineform proxy with alpha in CS6
Posted by Anmol Mishra on February 28, 2018 at 10:46 pmHi. I am on after effects CS6. I have a chromakey comp. I right clicked on the comp -> create proxy -> movie
In the render options I chose cineform, rgb+alpha, trillions+, premultiplied unmatted.
The file shows a black background in VLC, qt7, as well as in after effects.
What am I doing wrong?
Anmol Mishra replied 8 years, 7 months ago 2 Members · 8 Replies -
Anmol Mishra
February 28, 2018 at 11:34 pmI’m using Sierra. CS6 works fine there. However I have experienced the same problem from mountain lion days.
Somehow the alpha channel is coming as a black layer.
Anmol Mishra
March 1, 2018 at 9:11 amJust for fun I rendered using prores 4444. No issues with alpha channel.
Walter Soyka
March 1, 2018 at 10:49 amIt’s been a while since I’ve used CS6. Can you post some screenshots that show your output module settings, and also the codec options for CineForm?
Walter Soyka
@keenlive | RenderBreak [blog] | Profile [LinkedIn] -
Walter Soyka
March 1, 2018 at 3:16 pm[Dave LaRonde] “Lesson learned! Cineform proxies don’t support alpha channels.”
Well… CineForm does support alpha, so I don’t think the matter is wrapped up yet.
CS6 was before native CineForm support was added to Creative Cloud. I think that Anmol may need to choose a CineForm profile that supports alpha in the Codec Options of the output module, but it’s been a while and I don’t remember what the dialog looks like. Those screenshots I asked for below will help.
Walter Soyka
Anmol Mishra
March 4, 2018 at 8:25 pm -
Walter Soyka
March 4, 2018 at 8:45 pmClick “Enable RGB encoding (4:4:4)”, then click “Enable Alpha Channel (4:4:4:4).” Save those settings into your output module.
Walter Soyka
Anmol Mishra
March 4, 2018 at 9:18 pmI get an error – Output module failed.
I had tried that option initially years ago when I started using CF. Still causes problems.
