Activity › Forums › VEGAS Pro › Cineform not working on new install
  • Cineform not working on new install
    Posted by Sebastien Gravel on June 8, 2010 at 7:18 pm
    Well, I’ve downloaded Cineform trial to edit some AVCHD. This is on a brand new install of windows 7 64 and Vegas 9 64.
    I get this error in Cineform log :
    GOTEC_ERRORABORT notification 0x80040228
    If this error shows up for a file, the rendered file will not playback.
    Sometime the file renders without error in the log, but the output will play at 2X speed without sound.
    I’ve also tried to update Cineform and I received this error log from windows.
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.ComponentModel.Win32Exception: An error occurred in sending the command to the application
    at System.Diagnostics.Process.StartWithShellExecuteEx(ProcessStartInfo startInfo)
    at System.Diagnostics.Process.Start(ProcessStartInfo startInfo)
    at CineForm.AboutBox.buttonUpdate_Click(Object sender, EventArgs e)
    at System.Windows.Forms.Control.OnClick(EventArgs e)
    at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ButtonBase.WndProc(Message& m)
    at System.Windows.Forms.Button.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
    CineFormActiveMetadataStatusViewer
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Users/Sabamie/AppData/Roaming/Microsoft/Windows/Start%20Menu/Programs/Startup/CineFormActiveMetadataStatusViewer.exe
    System
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Configuration
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the computer
    rather than be handled by this dialog box.
    I have yet to hear from the Cineform support…
    Any suggestions?
    Sebastien Gravel replied 16 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
