Activity Forums Compression Techniques Cineform Avi to prores?
  • Cineform Avi to prores?
    Posted by Sander Lowie on October 17, 2011 at 2:46 pm
    Hello.
    I switched from a PC to a mac a while back. When i worked with my pc I converted some h.264 material from a long running project I’m working on to Avi Cineform Codec because I could not edit with my PC properly. Unforunately I lost my original camera files and I’m now stuck with my Cineform codec files wich are, ofcourse, unusable with a mac.
    Is there any way to convert these files back? They can only be played on windows movie maker.
    Thank you
    Sander
    Don Huckleberry replied 14 years, 10 months ago 2 Members · 1 Reply
  • Don Huckleberry
    November 6, 2011 at 8:55 am
    Sorry for the late reply, was poking around and found this msg.
    You should be able to use the free NeoPlayer to decode it on Apple:
    https://estore.cineform.com/neoplayer.aspx
    It’s been a couple years since I used it, but it worked well between our macs and win machines. You might have to rename your .avi to .mov – can’t remember. Download renameit off of download.com if you need to rename a bunch of files.
    Hopefully you already found this.
    Don
