Activity › Forums › Adobe Premiere Pro › Cineform AVI Importing Problem
  • Cineform AVI Importing Problem
    Posted by Michael Gurevich on September 13, 2010 at 6:42 pm
    I am experiencing something I’ve not seen yet and am not sure how to get around or through it. If you do, please let me know.
    I’ve converted a bunch of AVCHD footage with Cineform NeoScene. Then I created a Premiere project and placed all of those clips on the timeline. The original footage was 1920×1080. I rendered out the entire timeline to 1440×1080 to match the resolution of the footage I’ll be mixing it with. Media Encoder produced one file that’s about 43 minutes long, encoded with the Cineform Codec, wrapped in AVI.
    I can play this file with Media Player Classic, and it works just fine and contains what seems to be all of the footage from all of the clips. But when I import the 43 minute clip into Premiere CS4, it only plays the first 43 seconds of it. The preview window only shows 43 seconds. When I drag it onto the timeline, only 43 seconds. I can’t expand the clip beyond that. There seems to be nothing I can do to use the entire clip.
    I ran MediaInfo on the clip and here are the results:
    General
    Complete name : C:\Temp\FFF Commercial\Canon\1440Canon.avi
    Format : AVI
    Format/Info : Audio Video Interleave
    Format profile : OpenDML
    File size : 29.4 GiB
    Duration : 43mn 46s
    Overall bit rate : 96.3 Mbps
    Video
    Format : CineForm HD
    Codec ID : CFHD
    Codec ID/Info : CineForm 10-bit Visually Perfect HD (Wavelet)
    Duration : 43mn 45s
    Bit rate : 94.6 Mbps
    Width : 1 440 pixels
    Height : 1 080 pixels
    Display aspect ratio : 4:3
    Frame rate : 23.976 fps
    Bits/(Pixel*Frame) : 2.538
    Stream size : 28.9 GiB (98%)
    Audio
    Format : PCM
    Format settings, Endianness : Little
    Format settings, Sign : Signed
    Codec ID : 1
    Codec ID/Hint : Microsoft
    Duration : 43mn 46s
    Bit rate mode : Constant
    Bit rate : 1 536 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Stream size : 481 MiB (2%)
    Interleave, duration : 42 ms (1.00 video frame)
    Interleave, preload duration : 166 ms
    I am not sure what to do. Please share your thoughts.
    Thank you,
    Mike
    https://www.supervarietyshow.com
    Michael Gurevich replied 16 years ago 1 Member · 0 Replies
  • 0 Replies
