Activity Forums Sony Cameras Cine EI footage noisy
  • Cine EI footage noisy
    Posted by Daniel Chisholm on December 18, 2021 at 7:25 pm
    Hi there,
    Just doing some tests with an FX9 and finding that on Cine EI, the footage always seems incredibly noisy, especially when compared to the SDR setting on the camera. This happens regardless of the ISO settings (even when matching native and actual ISO).
    Is that normal? And if so, is that just the payoff for getting the higher dynamic range?
    Dan
    Daniel Chisholm replied 4 years, 5 months ago 2 Members · 2 Replies
  • Tim Neighbors
    March 31, 2022 at 2:54 am
    I think if you’re using Slog 3, you’ll want to expose a little higher and use a lut that pulls things down as opposed to pulling them up. Slog 3 I believe is more for preserving details in the darks, whereas Slog 2 is more about preserving details in the brights.
  • Daniel Chisholm
    March 31, 2022 at 9:36 am
    Hi Tim! Many thanks for the response! That makes a lot of sense! Will try the difference between Slog 2 & 3 in practice next time! Much appreciated! 🙂
