Activity Forums Zaxwerks chunky shadows with AE lights
  • chunky shadows with AE lights
    Posted by Hugh Howarth on January 18, 2006 at 2:23 pm
    I am trying to use the AE Comp Camera and Comp Lights (AE 6.5) with Zax 3D elements (4.0.6). I have imported many layers to create my 3D, but am getting terrible-looking shadows cast from my AE lights onto the imported surfaces.
    This is with Invigorator Renderer. With High-Quality OpenGL, everything is smooth, but the lighting is WAY different; many lights don’t seem to show up (spots) while others do.
    Are these simply limitations with Zax or am I missing something? Any help would be much appreciated.
    Hugh
    Hugh Howarth replied 20 years, 8 months ago 2 Members · 2 Replies
  • John Dickinson
    January 19, 2006 at 5:00 am
    In the 3D Invigorator Setup window (on the small object tab) there is a button for USER PREFS; click on that and you’ll find a SHADOW QUALITY setting. Try increasing this and see if it helps.
    JD
    John Dickinson
    Motionworks
    http://www.motionworks.com.au
  • Hugh Howarth
    January 19, 2006 at 3:49 pm
    Thanks for the info John. I found the issue was simply that I had my AE light’s shadow diffusion set to “0”. Increasing it slightly solved the issue. Now I’ll pump up the shadow quality in User Prefs.
    Hugh
