Activity Forums Adobe After Effects chrome reflections
  • chrome reflections
    Posted by Christian Buettner on May 15, 2005 at 9:09 am
    Hi there …
    could someone give me a hint on how to achieve an effect often used in commercials: let´s say there is this sort of a logo where at the end of all these animations there´s allways some kind of reflection moving over the surface. Know what I mean?
    I presume not all of those effects are made in 3D. I´d rather guess it´s done by adding the same source material into another layer , then mask out a thin line, animate it over time to get the movement and finally using some apply mode like add or something.
    Am I right or completely wrong? Any hints welcome …
    greets
    editm
    Christian Buettner replied 21 years, 3 months ago 4 Members · 4 Replies
  • Barend Onneweer
    May 15, 2005 at 11:03 am
    Well, true chrome reflections are a bit more complicated, but what you seem to be referring to is often called a ‘glint’ effect.
    It can be achieved in many different ways, for instance by animating a white feathered solid over the logo, using an add or screen transfer mode with reduced transparancy.
    But you could indeed also duplicate the source (logo), and apply an animated feathered mask to the top layer, and set it’s transfer mode to add or screen. Maybe also blur the top layer a little, and play with the brightness levels of the top layer.
    To cheese it up a little, you could even add a really subtle lensflare onto the glimmer effect. But make it really subtle so nobody actually sees the flare.
    Bar3nd
    Forum COWmunity leader for:
    ADOBE AFTER EFFECTS
    MAGIC BULLET SUITE
    INDIE FILM & DOCUMENTARY
  • Filip Vandueren
    May 15, 2005 at 2:32 pm
    There are also some plugins that do it for you.
    Hans Van vliet
    May 16, 2005 at 12:59 pm
    Hey,
    If you mean that because it’s chrome it reflects the enviroment around it. Best thing is to use the logo (text or what ever) as a travelling matte for the relfection map / background (choose a nice sky background or something for that) and then use displacement map (using the logo again) over the actuall background. Place this above the logo, and use ADD/SCREEN Multiply or OVERLAY and adjust the opacity down. You’ll get a nice reflective chrome look. You might want to blur the background layer to it’ll soften it out a bit. Then overlay this GLINT look the others are talking about.
    damn, hope that makes sense ..
    Good luck.
    ..::hunz..
  • Christian Buettner
    May 19, 2005 at 2:26 pm
    Thanks guys …
    I
  • We use anonymous cookies to give you the best experience we can.
