Activity › Forums › Adobe After Effects › Chromatic Abberation
  • Chromatic Abberation
    Posted by Joe Pallagio on January 18, 2008 at 10:05 pm
    I was just going through the old posts concerning Chromatic Abberation and I had a couple questions. What is the Sapphire plugin that would do this, and when I split out my footage into 3 channels and then screen the top 2 over the third the image is now black and white. Do I need to put my original footage back over the separate channels? Any help would be appreciated. Thanks.
    J
    Darby Edelen replied 18 years, 8 months ago 2 Members · 1 Reply
  • Darby Edelen
    January 19, 2008 at 12:47 am
    [Joe Pallagio] “when I split out my footage into 3 channels and then screen the top 2 over the third the image is now black and white.”
    It sounds like you’re not splitting the channels properly. What effect are you using?
    If you use Channel > Shift Channels then you should have these settings for your Red layer (for example):
    Alpha – Alpha
    Red – Red
    Green – Full Off
    Blue – Full Off
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
