Activity Forums Adobe Premiere Pro Chroma/Saturation Limits for Computer/Web Playback?
  • Chroma/Saturation Limits for Computer/Web Playback?
    Posted by Ivan Myles on April 26, 2013 at 10:04 pm
    Is there a computer/web equivalent of broadcast safe limits for chroma and saturation?
    I am preparing an H.264 encode for computer/web viewing. Luma was adjusted to reduce the white point, and the Video Limiter effect was applied with Luma limits of 0% and 100%. As a result, the maximum Y-value is below 100 IRE, although there are a few points where the minimum drops below 0 IRE.
    Chroma min/max was set to -20%/120% using the Video Limiter effect. There are a couple of points in the encoded video where saturation is pretty high (see image below). Should I reduce the Chroma limits to 0% and 100%? This tends to clip RGB values around 95 IRE. Alternatively, I could just desaturate the problem clips. Any thoughts?
    Ivan Myles replied 13 years, 4 months ago 2 Members · 2 Replies
