Activity › Forums › Blackmagic Design › Chroma&Luma Shift with 10Bit 4:2:2
Posted by Jo. S on May 8, 2005 at 9:33 pmHi!
Did anyone else notice the significant Luminance-Shift using BMD-codecs ?
IMihail Angelov replied 21 years, 3 months ago 4 Members · 3 Replies -
Adolfo Rozenfeld
May 9, 2005 at 12:31 amIt isn’t technically a shift in the Blacmagic codec (they wouldn’t make such a big mistake!), but a small compatibility issue in the way images are decoded by Final Cut Pro. It was extensively discussed a couple of months ago, but as far as I know there isn’t a fix yet. It’s a signficant issue, but it wasn’t clear to me if the solution has to come from Blackmagic, Apple or both 🙂
Adolfo Rozenfeld
Buenos Aires – Argentina
https://www.adolforozenfeld.com
adolfo@adolforozenfeld.com -
Jorge Torrens
May 9, 2005 at 7:07 amI’m seeing the same problem in quicktime when I recode a BMD file to something else, be it animation or media100HD or cinewave.
Not only in final cut.Jorge Torrens
Hillvalley SL
Producciones Audiovisuales -
Mihail Angelov
May 9, 2005 at 11:10 ami had this problem with 4.7.5 driver for Windows (I use Decklink Pro + Premiere Pro), but with 4.8.1 this problem disappear.
