Chromakey issue in Keylight…horrible noise
I tried to light as evenly and well as possible, but I may very well be doing everything wrong.
I have a Reflecmedia Chromaflex setup and I used 3 Litepanel 1x1s (2 floods, and 1 spot) to light my subject, spot for key and 2 floods for backlights. I made sure the subject was close to the screen as it has to be for Reflecmedia to work correctly. Apparently the rules are the exact opposite of traditional green screen (where you would normally place the subject far from the screen).
So here is my Reflecmedia setup:
And here are two clips I posted:
I’d be very interested if anyone could experiment with these two Apple Pro Res HQ files using AE Keylight and tell me if you get noise as soon as you apply the chromakey, which has been my experience so far. The odd thing is that I don’t see any noise in the original unkeyed footage only once the key is applied.
I sure I’m making a lot of mistakes because everyone else seems to be getting clean results with Reflecmedia. I just wish I could solve the problem.
