Activity Forums Adobe After Effects Chroma sub-sampling preview
  • Chroma sub-sampling preview
    Posted by Nathan Grout on June 27, 2013 at 10:07 pm
    I’m doing some graphics work that involves contrasting colors separated by sharp edges. When these edges are curves or diagonals, they look more pixelated when rendered to 4:2:2 than when rendered to 4:4:4, or even within After Effects itself. This makes sense as an artifact of the chroma subsampling used. Here’s my question: is there a way to preview video in After Effects that takes chroma subsampling into consideration? Is there a way to set After Effects to a 4:2:2 preview mode?
    Walter Soyka replied 13 years, 2 months ago 2 Members · 1 Reply
  • Walter Soyka
    June 28, 2013 at 1:54 pm
    Not directly.
    If you’re using CS4 or CS5/CS5.5, you can use qp_ChromaSubsample [link].
    CS6 and higher (or CS3 and lower), you have to make your own. You can get a decent approximation by adding an adjustment layer with the following effects:
    Channel Combiner (set to RGB to YUV)
    Channel Blur (Red:0, Green:2, Blue:2)
    Channel Combiner (set to YUV to RGB)
    I recommend making this adjustment layer into a guide layer so you don’t accidentally render it.
    Walter Soyka
