Activity Forums Apple Final Cut Pro Legacy Chroma Key troubles (DV)
  • Chroma Key troubles (DV)
    Posted by Tim Taylor on July 14, 2006 at 11:48 am
    I’m having trouble getting a good key from my DV green screen footage.
    Subject is african american, and shot head to toe with very little movement.
    The problem is very noticable green reflected light on his head and shoulders.
    In hindsight, the solution would probably be more seperation between subject and background,
    but are there any proceedures, tricks, plugins, Etc. that will improve the look of my existing video?!?!
    Thanks for the help!
    Tim Taylor
    RESolution Media Services, LLC
    Daniel Serrano replied 20 years, 2 months ago 7 Members · 7 Replies
  • 7 Replies
  • Reno70
    July 14, 2006 at 1:27 pm
    dv is hard to key in the first place but try using the matte choker and or spill supressor plug-ins. the spill supressor will help reduce the green screen reflection on your subject and the choker will help you fine tune the matte around your subject. good luck!
    shoot.cut.score
  • Tore Jonssen
    July 14, 2006 at 1:38 pm
    Check out DV Matte blast. Keying with DV is hard enough, this might help you out. https://www.kenstone.net/fcp_homepage/review_dv_matte_blast_douglas.html
  • Tim Taylor
    July 14, 2006 at 1:52 pm
    For some reason I was having trouble getting good search results. Can’t remember exactly what I did differently last time, but voila – I got lots of threads!
    I knew this topic must have been covered pretty well.
    I got a lot from Kevin Monahan’s article
    https://www.kenstone.net/fcp_homepage/chroma_key_fcp_hd_monahan.html
    I’m also looking at dvMatte.
    Thanks all, for your responses!
    Tim
  • Arnie Schlissel
    July 14, 2006 at 2:41 pm
    If you have Motion, try keying the shot there, & then you can import the motion project into FCP & drop it into your timeline. Motion has Primatte, which is a very good keyer. You can also buy a version of DV Garage’s keyer for motion.
    Arnie
    Now in preproduction: Peristroika (Cosmological Congress), a film by Slava Tsukerman
    https://www.arniepix.com
  • Chris Poisson
    July 14, 2006 at 3:22 pm
    DVMatte Pro for FCP is very easy to use and VERY good, and DVmatteBlast in Motion will blow you away. Very easy.
    Have a wonderful day.
  • David Healy
    July 14, 2006 at 9:11 pm
    dvmatte is your best bet for 4:1:1 video or miniDV. Nattress has a few plug-ins that may also aid in obtaining good chromakeys, provided your green screen scenes had proper lighting
  • Daniel Serrano
    July 17, 2006 at 3:04 am
    you can try Conduit.. its on the dvgarege.com site
    it even has a greenscreen sample taht probably is like the one you are working on….
    and has a little video about it too… check it out…
