Activity Forums Adobe After Effects chroma key question.
  • chroma key question.
    Posted by Benito Sanz on October 23, 2007 at 3:05 pm
    hi all.
    i’ve got some footage shoot on green screen, the problems is that it’s got a lot of spill or green reflected in the skin and when i pull the key using keylight it takes all the green in the skin and it looks very grainy.
    is there any way to reduce the grenn in the skin without affecting the green in the chroma, like any color balancing, or any control inside keylight.
    thank you very much.
    Alex Dinnin replied 16 years, 11 months ago 3 Members · 3 Replies
  • Erik Pontius
    October 23, 2007 at 4:06 pm
    I’d suggest sitting down with the keylight PDF manual. There are controls such as alpha/despill bias, screen balance, foreground color correction, edge color correction and other tweaks that can be used to improve the quality of your key.
    Also there are a couple of tutorials at the COW that can give you some tips on improving a key. The Super Tight Junk Mattes tutorial is especially useful when dealing with greenscreens that were not lit properly.
    Erik
  • Benito Sanz
    October 24, 2007 at 7:54 am
    thank you very much Dave, extremely helpfull your tips, it did the job perfectly.
    thanks
  • Alex Dinnin
    September 18, 2009 at 10:20 am
    What was the way Dave ?? it just comes up with
    Here’s one way to do it:
