Chroma Key Problems
Hi, first post here so hello. All my other queries in the past have been solved by simply reading other posts on the site so thanks everybody.
I’ve not used Chroma Key on FCP before but am editing together a project using some green screen. After shooting I did a quick test on iMovie to see if it would key properly and it worked well.
So I’ve edited my main video together and am now looking to add other footage into the green screens. I’ve followed several tutorials on YouTube and am going slowly mad.
Window panes in a room were covered (on the inside) with green screen material and people moved in front of them. The idea being that the ‘outside’ could be added later on.
There are two problems so far:
1. When I go to click onto the window panes with the dropper tool it keys out the white window frames (at least part of them).
2. If I try and playback after adding the second video track with the incorrect part keyed out I simply get an ‘unrendered’ message.
All footage has been converted to pro Res LT.
I really appreciate any suggestions
