Activity Forums VEGAS Pro Chroma key not showing in the preview window
  • Chroma key not showing in the preview window
    Posted by Cain Nuke on July 28, 2014 at 12:48 pm
    recently im having problems with the preview window in Vegas 12 since its not showing what it should. Long time ago I created a template project file which i have been using so many times now as base for all my future projects. There i have some media that has chroma key applied so they lose their background. However, today i opened the file and i found that the background is there in all shots. I even checked back old projects files and all of them have the same problem. I havent changed anything in the settings or whatsover so i dont understand why is this happening because if i render the file the output looks fine. It only occurs on the preview window.
    Also, some days earlier i had already noticed a different problem with the preview window too. If i crop a shot and i extend it on the time line it doesnt show properly on the preview as i play it. It looks squeezed instead of cropped. It looks fine when stopped and in the output. Why? Is there anyway i can fix this?
    Thank you.
    Erol Cam replied 6 years, 4 months ago 4 Members · 18 Replies
  • 18 Replies
  • Graham Bernard
    July 28, 2014 at 12:53 pm
    On the Preview Toolbar, check you haven’t Selected FX BYPASS.
    G
  • Steve Rhoden
    July 28, 2014 at 1:08 pm
    That is correct, in the Split Screen View icon.
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
  • Cain Nuke
    July 28, 2014 at 1:20 pm
    Thank you, it was checked for some reason. Maybe I pressed it by mistake. This fixed the chroma key problem but i still have the other issue with the squeezed images. That looks more like a bug rather than a wrong setting.
  • Graham Bernard
    July 28, 2014 at 1:35 pm
    Supply a Screengrab.
    G
  • Cain Nuke
    July 28, 2014 at 1:54 pm
    Here is my pan/crop window
    https://i.imgur.com/uzgxe8H.png
    Here is how it looks on the preview when stopped and how it is supposed to actually look:
    https://i.imgur.com/UKmmvYI.png
    This is how it looks on playback:
    https://i.imgur.com/l09NGb5.png
    Thank you.
    View post on imgur.com
  • Graham Bernard
    July 28, 2014 at 2:16 pm
    Somewhere amongst your settings you’ve not matched the PAR to the Settings.
    Grazie
  • Cain Nuke
    July 28, 2014 at 2:21 pm
    Sorry what you mean with the PAR?
  • Graham Bernard
    July 28, 2014 at 2:24 pm
    Pixel Aspect Ratio = PAR
    What Version and Build of Vegas are you using?
    G
  • Cain Nuke
    July 28, 2014 at 2:34 pm
    Vegas 12 build 367 64 bit
  • Graham Bernard
    July 28, 2014 at 2:51 pm
    [Cain Nuke] “Vegas 12 build 367 64 bit”
    Well, you’re someway behind the curve – the last Build was B770.
    Well, saying that, I’m NOT seeing a Build 367?… And this for the next Build up from you:-
    Notable fixes/changes in version 12.0 (Build 394)
    Fixed an issue that could cause image stretching for certain PNG files when used with Pan/Crop.
    I had to read the WHITE Paper on VP 12 for you
    Read it, and you’ll see a lot of Pan/Crop activity went ahead. But your Build367 ain’t mentioned . . hmm…
    Grazie
