Activity Forums Adobe Premiere Pro Chroma Key In Premiere
  • Chroma Key In Premiere
    Posted by Lawrence Vaughan
    on October 17, 2006 at 8:36 am
    I have a shot in a film which the top half is the sky, and the bottom half the ground. I have another shot, which is of someones face and I am wanting to merge it “in the clouds” of the previous shot.
    The only trouble is – the shot of the face was not shot on a blue screen, so the only way I can figure out how to do it is to export a frame of the face, cut out the background in photoshop and then place it in premiere.
    The only trouble is – it looks kinda lame, as it is a static image.
    Is there any way of doing it (in either premiere 6.5 or pro) or do I need some additional software to get the results I want?
    Lawrence Vaughan
    replied 19 years, 11 months ago
    3 Members · 4 Replies
  • Harm Millaard
    October 17, 2006 at 10:20 am
    Have you tried the 16-point garbage matte in combination with the chroma key?
    BTW, for chroma keys I suggest to use Ultra-2.
    Harm Millaard
  • Lawrence Vaughan
    October 17, 2006 at 1:50 pm
    I will try it after work and get back to you.
    thanks
  • Tim Kolb
    October 17, 2006 at 2:31 pm
    Or you may want to create a soft edged matte (blurry white area for the face and black for the composition you want to cut out) and track-matte it. If you want the face in the clouds, full opacity may not be desirable either…
    TimK,
    Director,
    Kolb Productions,
    Creative Cow Host,
    Author/Trainer
    http://www.focalpress.com
    http://www.classondemand.net
  • Lawrence Vaughan
    October 20, 2006 at 10:35 am
    Hi again.
    Many thanks for the help. The 16point garbage matt seems to be fine, is there a way to add more points for finer detail, or a different effect which achives the same results, but with more control?
