Activity Forums Apple Final Cut Pro Legacy Chroma Key Editing
  • Chroma Key Editing
    Posted by Dustin Daniels on April 9, 2009 at 6:55 pm
    We just did our first green screen shoot and it turned out fine. We used Premiere Pro 2 (okay quit your snickering)for this project, and I know this is just another reason to upgrade this system. But we also use Final Cut Pro.
    My question is this, if we are going to be doing a lot of this type of work, and it looks like we are….what’s the best software for Keying?
    Is Final Cut the way to go, or maybe it’s a plug in?
    Thank you so much for your help,
    Dustin Daniels | http://www.sozovideo.com
    Stephen Smith replied 17 years ago 8 Members · 8 Replies
  • 8 Replies
  • Ron Craig
    April 9, 2009 at 8:28 pm
    The best way I have found is the Keylight plugin in After Effects.
  • Mark Suszko
    April 9, 2009 at 8:39 pm
    We got Ultimatte AdvantEdge, at the time it was the top dog especially for DV footage and sub-par footage. But I get good results with the stock keyer in FCP as well. I also use the Diamond keyer in Combustion.
  • Elijah Lynn
    April 10, 2009 at 6:11 am
    A few of the keyers you will want to demo are:
    Primatte Keyer Pro (slow but good, only uses 1 core, I use this one)
    Boris Keyer (don’t know the name)
    DV Matte Pro (uses GPU and is very fast)
    Primatte RT (comes with Motion 3, essentially free, also fast)
    Keylight (highly talked about)
    Of course it is all about the source footage. But assuming you have done a good job with that then those are your options.
    FCP’s built in Keyer has a reputation just slightly above that of Premiere’s keyer. There have been a lot of jokes when it comes to poorly keyed footage, one I hear the most is, “Did you use premier to do that” and the lesser is, “Did you use the built in FCP keyer for that”.
    Cheers,
    Elijah
  • Marcelo Lewin
    April 10, 2009 at 4:01 pm
    What camera are you shooting your green screen with? Yes…the keyer is very important, but make sure you:
    #1 – Shoot with a good camera that supports 4:2:2 color space (if your budget allows for that)
    #2 – Light the screen separately from the talent.
    If you can, get yourself a Canon HV 20 or HV 30 (under $800) and shoot and record directly to hard drive via HDMI, you can shoot HD with 4:2:2 color space and it will certainly help you in the keying process (you’ll be able to use almost any keyer and get great results).
    You can see what I mean here re: the HV 20/30:
    https://www.cinematography.com/index.php?showtopic=37656
    Anyhow… good luck and post what you used (keyer wise) and your results with it. I’m intrigued.
    Cheers!
    Cheers!
    – Marcelo Lewin
    Pixel Heads Network
    https://www.PixelHeadsNetwork.com
  • Sascha Engel
    April 12, 2009 at 12:05 pm
    I agree with Marc. For me Ultimatte Advantage is by far the best plug in for Green Screen work, speciall if you work with lower resolution like MiniDV. Even with not so well lit Green Screens I got amazing results. Just takes a bit to get into the interface, but once you have it – no problem.
    Sascha Engel
  • Stephen Smith
    April 27, 2009 at 7:29 pm
    Mark and Sascha,
    What resources did you turn to to learn Ultimatte AdvantEdge?
    Salt Lake Video
    Check out my DVD Money Making Graphics & Effects for Final Cut Studio 2
  • Adam Simonsen
    May 2, 2009 at 6:48 pm
    I would be sooo thankful if someone could post me a link to a great article that Stephen Smith wrote in may-june edition of Creativecow magazine in 2007.
    Would absolutely make my day- thanks, Adam Simonsen.
  • Stephen Smith
    May 4, 2009 at 2:39 pm
    Thanks for asking, here is a link to the COW magazine that has the article, “Perfect Color-key: A Checklist”.
    https://magazine.creativecow.net/issue/power-of-artistic-passion
    Lone Peak Productions
