Activity › Forums › Adobe Premiere Pro › Chroma Key and Transitions
  • Chroma Key and Transitions
    Posted by Jeff Hughes on September 2, 2008 at 7:02 pm
    I am trying to add a white flash to a video track that is being chroma keyed. Instead of the flash working on just the existing subject (keyed element) the flash is seen full screen. Is it possible to add this effect to only the chroma key area and not the entire screen? Thank you in advance,
    Jeff
    please email at:
    jeff@mypromohouse.com
    Jon Barrie replied 18 years ago 2 Members · 1 Reply
  • Jon Barrie
    September 3, 2008 at 12:30 am
    If you think of the process as layered, the keyed footage would need to be absolutely on top. Then the white flash, then the BG on the bottom.
    Layer 3 = Key
    Layer 2 = White Flash
    Layer 1 = BG
    – Jon Barrie 🙂
    How many editors does it take to change a light bulb?
    http://www.jonbarrie.net
