Activity Forums VEGAS Pro Chroma key acting weird
  • Chroma key acting weird
    Posted by Diogo Saraiva on June 11, 2021 at 1:05 am
    After I start doing chroma key with the image below
    With black blackground it gets well
    But when I try to make the background white
    After I tune it, it starts to be blue
    What am I doing wrong?
    Francois Pénzes replied 5 years, 2 months ago 3 Members · 2 Replies
  • Steve Rhoden
    June 15, 2021 at 2:13 pm
    If you are using the Vegas built in Chroma Key filter, it somewhat has some limitations!
    But in the meantime, why don’t you just simply put a solid white background behind that individual after keying!
    However, for serious Chroma key work, its advisable to invest in purchasing a more powerful option, which would be FXHome Ignite Pro or Borisfx Continuum Primatte Studio, they both include industry standard Keying features.
  • Francois Pénzes
    June 16, 2021 at 1:06 pm
    Hi Diogo
    As Steve said, the ignite Pro plugin from FXHome works great. Once you install Hitfilm, the plugin will be available in Vegas also.
    From what I can see by one of your pics, the one with the green BG, you are standing way to close to your screen, hence the dark spot around you. If the camera sees a shadow, for sure you will have a harder time to key it out. In order to work best, the green (or blue) BG has to be evenly lit. Preferably, the BG will have a different lighting source than your subject. Also add a top of the head back lighting in order to better define your subject from the BG (but don’t go too harsh).
    Do a couple of test runs with your environment a go with what works best.
    Cheers !
