Activity Forums Lighting Design chroma green fabric for flood light
  • chroma green fabric for flood light
    Posted by Ian Maclean on May 28, 2009 at 12:28 am
    I’m getting a couple of Fluorescent flood lights (18″ Reflector) to light a 9′ paper greenscreen backdrop. I’d like to supersaturate the backdrop by stretching some green fabric over the reflector, but I’m not sure where to look or what, exactly, to get.
    Any specific recommendations would be great. I’m imagining some kink of parachute / spinnaker nylon fabric, but had a poly muslin recommended to me by the nice lady at Rose Brand. I didn’t find anything on this specific setup searching this topic, but did try. Many thanks.
    Ian Maclean replied 17 years, 3 months ago 5 Members · 10 Replies
  • 10 Replies
  • Dennis Size
    May 28, 2009 at 4:18 am
    Why not just use color correction color media?
    Here are 3 suggestions:
    1) LEE Filters #244 “Lee Plus Green”
    2) LEE Filters #243 “Lee Fluorescent 3600K”
    or the “very bold”
    3) Rosco #4460 “60 green”
  • Michael Palmer
    May 28, 2009 at 4:32 am
    ” I’d like to supersaturate the backdrop by stretching some green fabric over the reflector”
    Adding fabric will reduce the lumens from the lamp. Follow Dennis’s recommendations. Just make sure you control the light to only the back drop. Its one thing to add light to the green screen but once you add color to these lights it must be contained to the area it is intended.
    Good Luck
    Michael Palmer
  • Michael Palmer
    May 29, 2009 at 5:37 pm
    Just get some good old fashion wooden clothes pins (aka C-47’s) and clip the gel on the front lamp. You can either purchase some Black Wrap or use use cooking foil from the kitchen drawer to create a snoot that extends beyond the front of the lamp over the gel to contain the light.
    Good Luck
    Michael Palmer
  • Ian Maclean
    May 29, 2009 at 5:43 pm
    Perfect, thanks. I think I read the fabric suggestion as a budget tip, but at around $20 a sheet, I can afford the filter (and JCX has them).
    How about tips on mounting the sheet to the reflector? I could cut the sheet into a circle, fit it in, and hold it there with black foil. Unless there are better suggestions? Many thanks.
  • Dennis Size
    May 29, 2009 at 8:50 pm
    $20 dollars a sheet??? !!!!!
    Buy it somewhere else. Your vendor is robbing you. Color media shouldn’t cost more than $8.00/per 24″ sheet.
    Once you settle in on the exact color correction that works best, buy a junior roll (for about $75.00). This colored mylar will fade with use/time, and you’ll need to replace it.
    As for attaching the color to your fixture — be creative (but good old fashioned gaffers tape, or black tak, is my method of choice).
    DS
  • Alan Lloyd
    May 30, 2009 at 12:36 am
    The black wrap will be very handy for “shrouding” the fixtures so that no green spill goes anywhere. Bottomers and siders ought to do it.
  • Ben Ferrer
    May 30, 2009 at 5:15 am
    JCX certainly doesn’t charge that much per sheet. I would double check your quote.
    Ben Ferrer
    DP – Transvideo Studios
    Mountain View, CA
  • Ian Maclean
    May 30, 2009 at 6:21 am
    I did get the quote wrong. It was in fact $7/sheet at JCX. So I got both the recommended Lee colors and think I’ll be set. Many thanks. As advised, I’ll tape the gell in place, and use Black Foil to control spill.
    The inexpensive two light kit I’m getting from Impact (VA903) comes with a diffuser disk. I’ll try it with and without of course, but any recommendations ahead of time? I haven’t even ordered the kit yet…
  • Dennis Size
    May 31, 2009 at 2:09 am
    You’re only using 2 of these lights …for a 9′-0″ greenscreen wall ??
    You should have at least 3.
    What are you using on your subject?
    DS
  • Ian Maclean
    June 1, 2009 at 3:38 am
    see new post. Thanks.
