Activity Forums Adobe After Effects Chroma and Luminance
  • Chroma and Luminance
    Posted by Joe Vallero on February 22, 2007 at 5:42 pm
    Hi Cow Community,
    I recently finished a job where we got a QC report on the final version and my graphics were causing Chroma and Luminance to peak. I am some what self-taught in Photoshop and After Effects and I don’t know how to make sure this doesn’t happen in the future, without changing the color in the Avid. Is there any tip on how to check the graphics before I insert them into my cuts.
    I used…
    Photoshop CS
    After Effects 6
    Avid Media Composer 11
    Thanks for any help.
    ED
    Hamish Boyd replied 19 years, 1 month ago 4 Members · 5 Replies
  • Charley King
    February 22, 2007 at 10:39 pm
    First rule of thumb. Never use color combinations over 235,235,235 White. or 16,16,16 black, for broadcast.
    If you keep everything below 235 and above 16 you should be ok in most cases.
    Charlie
  • Joe Vallero
    February 22, 2007 at 11:14 pm
    That makes sooooooo much sense I can’t believe i didn’t think of it. The simplest answer is usually the right one.
    Thanks for the tip though this is great.
    ED
  • Joe Vallero
    ED
  • Mark Suszko
    February 23, 2007 at 7:41 pm
    As insurance, you can apply the broadcast safe filters,( and should have those warnings turned on at all times ) but it is always better to make it right from the start than to apply bandages to the problem footage.
  • Hamish Boyd
    August 2, 2007 at 2:23 am
    Something I have always done that has never failed me yet is to put an adjustment layer on the top of your master comp in AE, apply levels filter and adjust the outputs. I only don’t set it as high as others have suggested. I do mine at 8 for black and 247 for white. Never been rejected for broadcast and when I have had the opportunity to test on proper scopes etc it all comes up ok.
    I’m in PAL land so not sure that makes a difference though.
    I think there was a tutorial about this ages ago here.
