Activity Forums Adobe After Effects Christmas tree lights lighting up.
  • Christmas tree lights lighting up.
    Posted by Anita Sancha on November 19, 2009 at 5:49 pm
    Any ideas of how to make a Christmas tree light up, the effect I want is the shop display of the xmas tree by day and by night illuminated.
    I have a still image of a decorated tree with lights taken in the day time, which I could darken. I can duplicate the layer and use something to keep the lightest parts brightest as an overlay maybe, or adjust the photo i.e in photoshop, but also how can I get that sparkle and color of the lights flickering. I cant go and film it either at night.
    Thanks Anita
    Thanks for all your help
    Anita Sancha.
    http://www.anitasancha.co.uk
    Chris Wright replied 16 years, 9 months ago 3 Members · 5 Replies
  • Anita Sancha
    November 19, 2009 at 10:07 pm
    Thanks Dave..
    Actually I don’t think I will mind a “cartoony” effect. I spent 15 years touring Europe with old animated mechanical hand painted magic lantern slides that dissolved through many layers using 5 different lenses projecting at the same time. It’s that effect of a gradual dissolve from day to night that I am looking for, with a bit of “gizmos”. But I am aware it would be technically “shit”. It’s just in the background, so I want sort of twinkles here and there, like diamond sparkles on a ring would be and then colored, as if a gel were superimposed. All this whilst one of the illuminated crap shop signs of a sledge and father Christmas flies by. Actally now I write it this does sound really awful.
    Still maybe I can experiment ..how best can I make a sparkle like on a diamond ring? and then I will just drop that in on some of the candles as I fade it. Give it some “bling!!!”
    Anita Sancha.
  • Anita Sancha
    November 20, 2009 at 8:29 pm
    Thanks Dave… I will try there.
    Anita Sancha.
  • Kevin Camp
    November 20, 2009 at 9:26 pm
    if you are color adjusting the tree photo to the point of black for everything except the lights, you may be able to use that layer with a blending mode of lighten, screen or add (probably screen or add) over a less darkened image of the tree.
    then you could try a layer with animated fractal noise on it as a track matte for the lights to get a bit of twinkle to the lights.
    but a particle system could work too. in particular, you’d use a layer shaped like the tree as your ’emitter’ and you’d probably need a custom particle that would a nested comp of the individual lights (a handful cut from the tree). velocity would be zero, and then you could animate the particles to appear all at once and you’d have an animated opacity for the particles (either in the particle precomp or in the particle settings>opacity over life). this way the lights would be in the same place. or, you could have the life span be short and have the opacity fade up then down over it’s life. this way is simpler, but the light placement will be random appearing all over the tree….
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Anita Sancha
    November 20, 2009 at 9:46 pm
    Gee thanks loads to experiment with.
    Anita Sancha.
  • Chris Wright
    November 21, 2009 at 10:37 pm
    don’t forget the effect Glow. It’s perfect for the hdr bulbs. Get some inspiration from some actual twinkle footage, and play around with wiggle expressions on brightness, glow, reflections, distortions, bloom presets. The fractal effect is a really good idea too, that’s how our own sky twinkles.
    Should be fun.
    p.s.
    here’s a random twinkle code
    Jumpy Wiggle 1 makes wiggle skip and hold rather than move fluidly.
    // Jumpy Wiggle 1 (moves at a random FPS)
    v=wiggle(5,50);
    if(v < 50)v=0; if(v > 50)v=100;
    v
    https://technicolorsoftware.hostzi.com/
