Activity › Forums › Adobe After Effects › Christmas Lights
  • Christmas Lights
    Posted by Matthew Preis on November 14, 2006 at 3:44 am
    I want to make a string of Christmas Lights that blink that I can letter box my screen with. I was going to make them in photoshop. What’s the best way to make them blink? Glow, Lights?
    Graham Quince replied 19 years, 10 months ago 3 Members · 2 Replies
  • Mylenium
    November 14, 2006 at 7:16 am
    Use a duplicate of the layer (or more specifically the lights that are supposed to glow) and put it on top of your normal layer using blendmodes such as Add or Screen. Animating opacity should give some good results. Of course you can use additional glows as well.
    Mylenium
    [Pour Myl
  • Graham Quince
    November 14, 2006 at 8:50 am
    I’d create a lit version and an unlit version in photoshop, then with glow applied to the lit version, I’d place all your lit bulbs over the top of you lit ones, then by either using Strobe or manually setting the opacity keyframes for one lit bulb layer, you should be able to use a simple expression to duplicate and delay the effect to your others, or you could manually copy-and-paste the keyframes to the other lights.
    Hope that helps
    Graham
    https://www.quinceweb.com – web design
    https://www.shiveringcactus.bravehost.com – Free FX for amateur films
