Activity › Forums › Apple Final Cut Pro Legacy › Choppy YouTube Export
  • Choppy YouTube Export
    Posted by Brian Darwin on April 10, 2011 at 8:14 am
    I just finished a project in FCP and when it’s exported it looks completely fine; when I upload it to YouTube, however, it gets slightly choppy and I can’t figure out what’s wrong. Here’s the video link: https://www.youtube.com/watch?v=OPn5pOt12qI
    The footage and sequence properties are as follows:
    Frame size = 720×486
    Vid rate = 29.97
    Compressor = Uncompressed 10-bit 4:2:2
    Data Rate = 28.9MB/sec
    Pixel Aspect = NTSC-CCIR 601
    Field Dominance = Lower (even)
    The export settings are as follows:
    Compression type = H.264
    Frame rate = Current fps
    Key Frames = Auto (frame reordering checked)
    Data rate = Auto
    Compressor quality = Best
    Size = Tried a few different ones (current, NTSC 720×486 4:3 and 16:9)
    De-interlace source vid checked and prepare for internet streaming checked @ fast start
    Anyone have any suggestions for better settings? This footage came from an old SD cam we were shooting on — hence the crappy 720×486 — but it just doesn’t feel as smooth on YouTube as it should. Given, some of the shots are pretty shaky, but it bugs me when I see it play smoother from the file on my desktop.
    Thanks for the suggestions in advance!
    Chris Tompkins replied 15 years, 5 months ago 3 Members · 7 Replies
  • 7 Replies
  • Rafael Amador
    April 10, 2011 at 1:03 pm
    [Devon Hennig] “The export settings are as follows:
    Data rate = Auto
    De-interlace source vid checked and prepare for internet streaming checked @ fast start”
    You shouldn’t let “Data rate: AUTO”. That makes a kind of huge uncompressed file.
    Limit the data rate. Try 2.000 Kbps.
    Your size/pixels is also wrong.
    You need to select “Square Pixels” and set a size keeping the 4×3 or 16×9 proportions (if your NTSC source is anamorphic).
    rafael
    http://www.nagavideo.com
  • Chris Tompkins
    April 10, 2011 at 1:22 pm
    Played smooth for me, didn’t see choppyness here.
    Chris Tompkins
    Video Atlanta LLC
  • Brian Darwin
    April 10, 2011 at 5:18 pm
    Thanks for the tip on the data rate; I tried 2kbps and the file came out really small (8mb) but the image was extremely pixely/blurry. I’ll try some other rates. For interest’s sake, how large do you think a 2.5 minute video file like this should be?
    Regarding the size/pixel issue: do I just need to change the sequence setting in the browser from NTSC-CCIR 601 to square pixels? The footage isn’t anamorphic, so in terms of the size in the export options, should I select NTSC 4:3? Or go with the current option? Thanks again, much appreciated.
  • Chris Tompkins
    April 10, 2011 at 6:44 pm
    I think he meant 2000kbs.
    Regardless, don’t change your sequence settings.
    Edit/finish in the highest settings.
    Export “Current Settings”
    THEN, Compress that file in Compressor or Episode or Squeeze or whatever you use for a compression program.
    Chris Tompkins
    Video Atlanta LLC
  • Rafael Amador
    April 10, 2011 at 6:58 pm
    [Devon Hennig] “Thanks for the tip on the data rate; I tried 2kbps and the file came out really small (8mb) but the image was extremely pixely/blurry. I’ll try some other rates. For interest’s sake, how large do you think a 2.5 minute video file like this should be?”
    Increase the data-rate as much as you can allow your self, but always keep it limited.
    [Devon Hennig] “Regarding the size/pixel issue: do I just need to change the sequence setting in the browser from NTSC-CCIR 601 to square pixels? The footage isn’t anamorphic, so in terms of the size in the export options, should I select NTSC 4:3? Or go with the current option? Thanks again, much appreciated”
    No.
    A 720×486 Square pixels picture is not 16×9 neither 4×3.
    If your original picture is anamorphic (16×90, you need to export to a new size which keeps the sides proportions (H x W = 16 x 9) so you must stick with values like;
    – 160 x 90
    – 320 x 180
    – 480 x 270..
    If your original source was 4 x3, the H x W relation must always be 4 x3, so you must stick to values like:
    – 240 x 180
    – 320 x 240
    – 400 x 300..
    rafael
  • Brian Darwin
    April 22, 2011 at 4:27 am
    Sorry it took so long for me to get back to this thread, but here’s another update.
    I just edited a roller derby video and the same kind choppiness is happening (https://www.youtube.com/watch?v=24-Cf_ndcoI). Again, this isn’t a buffering problem (it still happens after the video has completely loaded); it’s a slight jittery choppiness that happens at random points throughout my videos, and never really in the exact same places. In addition, the clarity seems pretty pixelly compared to other 360p videos online. The vids aren’t as choppy and unclear in 720p, obviously, but one of my questions is why doesn’t my 360p quality seem as clear and smooth as other 360p YouTube videos (I.E,. any music video, College Humour video, etc? I know they’ve got better equipment, but I’m shooting with a Sony EX1, which isn’t a terrible cam). Something tells me that I’m not color correcting correctly either – could this be part of the problem? I’m self taught, so I’m not sure what’s “acceptable” for color levels… I just sort of go until it looks good — any info on this would be great. Sorry for being so irritatingly amateur…
    Here’s the media info stats for the Roller Derby video I posted above in case anyone’s curious (info collected by MediaInfo program):
    General
    Complete name: /Users/TVZ/Desktop/Projects/Roller Derby/Exporting/Audio Correct/Roller Derby Final.mov
    Format: MPEG-4
    Format profile: QuickTime
    Codec ID: qt
    File size: 137 MiB
    Duration: 2mn 22s
    Overall bit rate: 8 047 Kbps
    Encoded date: UTC 2011-04-20 20:28:36
    Tagged date: UTC 2011-04-20 20:28:38
    Writing library: Apple QuickTime
    Video
    Format: AVC
    Format/Info: Advanced Video Codec
    Format profile: Main@L3.2
    Format settings, CABAC: No
    Format settings, ReFrames: 2 frames
    Codec ID: avc1
    Codec ID/Info: Advanced Video Coding
    Duration: 2mn 22s
    Bit rate mode: Variable
    Bit rate: 7 911 Kbps
    Width: 1 248 pixels
    Original width: 1 280 pixels
    Height: 702 pixels
    Original height: 720 pixels
    Display aspect ratio: 16:9
    Frame rate mode: Constant
    Frame rate: 59.940 fps
    Color space: YUV
    Chroma subsampling: 4:2:0
    Bit depth: 8 bits
    Scan type: Progressive
    Bits/(Pixel*Frame): 0.151
    Stream size: 134 MiB (98%)
    Language: English
    Encoded date: UTC 2011-04-20 20:28:31
    Color primaries: BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
    Transfer characteristics: BT.709-5, BT.1361
    Matrix coefficients: BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
    Audio
    Format: AAC
    Format/Info: Advanced Audio Codec
    Format profile: LC
    Codec ID: 40
    Duration: 2mn 22s
    Bit rate mode: Constant
    Bit rate]: 128 Kbps
    Channel(s): 2 channels
    Channel positions: Front: L R
    Sampling rate: 48.0 KHz
    Compression mode: Lossy
    Stream size: 2.16 MiB (2%)
    Language: English
  • Chris Tompkins
    April 22, 2011 at 11:32 am
    Color correcting will have nothing to do with playback choppiness.
    Your vid looks fine. It’s a compressed file for web.
    Want it cleaner and smoother? Up the data rate when compressing for web.
    In 720 mode it looks clean.
    It looks like you shot 720p_60
    Did you compress to a 30FPS file? Youtube prefers that I believe.
    Also: Height: 702 pixels
    This doesn’t make sense. You should compress using the same size as the original 720 file if you want an 720pHD option on the u-tube version.
    Chris Tompkins
    Video Atlanta LLC
