Activity Forums VEGAS Pro Choppy Video Playback Vegas 9
  • Choppy Video Playback Vegas 9
    Posted by Frank Ventimiglia on October 26, 2010 at 11:55 pm
    Well my problem is with the video playback when I’m trying to edit a video in sony vegas pro 9. My video even, on the lowest playback setting, is extremely choppy and extremely hard to edit. I am editing 720p HD video recorded from a kodak zi6. My laptop specs are…
    Asus K70AB
    AMD Turion RM75
    4GB RAM
    ATI Mobility Radeon HD4570; VRAM 512MB
    Can someone explain if my specs are the issue, or if it’s something else.
    John Rofrano replied 15 years, 11 months ago 3 Members · 5 Replies
  • John Rofrano
    October 27, 2010 at 1:23 am
    [Frank Ventimiglia] ” My video even, on the lowest playback setting, is extremely choppy and extremely hard to edit. I am editing 720p HD video recorded from a kodak zi6.”
    Make sure that your project is set to match your media settings (720p). This can have a big impact on playback. If you recorded at 60fps stop doing that. 30fps is plenty and will play back much smoother. Vegas Pro 10 handles this footage much better than 9 does. I would download the trial of 10 and see if it makes a significant difference. If it does, that would be the easiest fix.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Dan Hart
    October 27, 2010 at 8:40 am
    Welcome to my world! Ive just posted a similar question.
    Im now praying for an answer…
    Cheers,
    Dan
  • John Rofrano
    October 27, 2010 at 10:53 am
    I can playback and edit Kodak Zi8 footage very smoothly on my old QuadCore 2.67Ghz with Vegas Pro 10a. You really need a QuadCore to work with AVC/h.264 and Vegas Pro 10 is optimized for this format now.
    ~jr
  • Frank Ventimiglia
    October 27, 2010 at 10:07 pm
    Well… I downloaded vegas 10a and it somewhat fixed my problem. If I have the quality set to good or less then it works fine. Even if I set it at a high res it’s still a lot less laggy the the version of 9 I’ve been using. Looks like I needa buy 10. Thanks for the help guys!
  • John Rofrano
    October 28, 2010 at 2:35 am
    Sony has really been working on optimizing these new camera formats so it makes sense to stay at the most current levels of software to get the latest benefits. Glad I could help.
    ~jr
