Activity Forums Adobe Premiere Pro Choppy video on export
  • Choppy video on export
    Posted by Andrew Gallucci on December 5, 2013 at 12:05 am
    Sorry if there are other posts on this but im cruising through my workload and figured it would be easier to post.
    For quick run and gun real estate videos, I use my canon mkII on manual, with time value of 50.
    I have been having export issues though with the .mov file. I know the footage is clean.
    My computer tends to have choppy playback on full HD, and Ive confirmed its related to that and not the actual clip.
    However, on export there tends to be some jitter, expecially with pans.
    Here is an example
    https://www.youtube.com/watch?v=EltoXO65_4o
    My export settings:
    h.264
    1920X1080, 29.97 fps, progressive, 100 quality, target 10mbps, max 10mbps
    Jeff Pulera replied 12 years, 9 months ago 2 Members · 3 Replies
  • Jeff Pulera
    December 5, 2013 at 3:49 pm
    Hi Andrew,
    Nice work, I want the house!
    What frame rate is the camera set to? Should be 1080p30, as 24p will give a more jerky look to panning shots. And then use a matching Sequence setting in Premiere to edit. Under “H.264” export options, there are YouTube presets, might be a better option than custom settings.
    Hope this helps
    Thank you
    Jeff Pulera
    Safe Harbor Computers
  • Andrew Gallucci
    December 6, 2013 at 3:40 am
    Thanks Jeff,
    Yeah the settings are matched. How did it view on your computer?
  • Jeff Pulera
    December 6, 2013 at 2:14 pm
    There is a strange choppiness to it. Sort of like 24p, but not quite, as if there is something else going on but I can’t say what.
    Jeff Pulera
