Activity › Forums › Adobe Premiere Pro › Choppy Video In Premiere Pro CS5!
  • Choppy Video In Premiere Pro CS5!
    Posted by Jorge Vargas on November 22, 2011 at 9:58 pm
    I captured a 5 min video with a Sony FX1000
    Im editing it on Premiere Pro CS5 and on premiere pro it plays back smoothly.
    When i export it. it play back skippy/ choppy. kinda like a scratched dvd.
    my sequence settings are: HDV 1080i
    When i export: These are the settings
    H.264 1080i
    please help
    Al Bergstein replied 14 years, 10 months ago 4 Members · 3 Replies
  • Jeff Pulera
    November 22, 2011 at 10:10 pm
    Hi Jorge,
    What is the destination of the exported clip? If viewing on the computer, then output should always be Progressive (deinterlaced), even when the source was interlaced.
    Jeff Pulera
    Safe Harbor Computers
  • Chris Tompkins
    November 22, 2011 at 11:14 pm
    Are you playing the file off the desktop?
    Laptop?
    USB drive?
    Chris Tompkins
    Video Atlanta LLC
  • Al Bergstein
    November 23, 2011 at 4:29 pm
    Jorge, what is the configuration of the machine you are running CS5 on? How much memory, etc. Has it ever played any footage back smoothly? It would be helpful to us to make sure that there isn’t some fundamental problem with the way you are using the product, rather than assume that the footage is the issue. As mentioned above, also knowing how the footage is being stored could lead to a solution.
    There is a place in your profile with the COW to put in your standard gear, so we can view it before replying . I looked there but didn’t find any info. Might be a good time to fill it out.
    Thanks and good luck!
    Alf
