Activity Forums Apple Final Cut Pro Legacy Choppy scrubs?
  • Posted by Paul Strilka on October 24, 2009 at 12:36 pm
    Why is it that 90% of the time- When I scrub through clips in the viewer or in the timeline it is not a nice smooth movement. It is very choppy as it skips through the footage. But-
    Occasionally- it does scrub through the footage as if it’s a knife through butter.
    It sometimes depends on the clips- certain clips scrub is nice others choppy.
    Sometimes a relaunch helps- but not much.
    Why all the inconsistencies?
    I would like to think it should always scrub through with ease.
    What could be causing this?
    I use the same settings and set-up.
    (XDCAM footage in a XDCAM timeline. G-tech espeed RAID )
    John Fishback replied 16 years, 6 months ago 3 Members · 3 Replies
  • Walter Biscardi
    October 24, 2009 at 12:54 pm
    My guess is that you have Snapping turned on when you have the “choppy” scrubs as this causes the playhead to snap to the end of each clip, and Snapping off when you have smooth scrubs.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author.
    HD Post and Production
    Biscardi Creative Media
    “Foul Water, Fiery Serpent” now in Post.
    Creative Cow Forum Host:
    Apple Final Cut Pro, Apple Motion, Apple Color, AJA Kona, Business & Marketing, Maxx Digital.
    Blog!
    Twitter!
  • Paul Strilka
    October 24, 2009 at 1:52 pm
    Thanks for the response but
    Nope. Tried it.
    Still very choppy scrub.
    I also tried turning on and off the HG scrub setting and that changes nothing as well
  • John Fishback
    October 24, 2009 at 4:45 pm
    Do you have this problem with codecs other than XDCAM? Also, how full is the G-Raid?
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
