Choppy Render Output
I’m using Premier Pro CS5.5. I’m using a Macbook Pro with :
2.2 GHz Intel Core 2 Duo processor
4 GB 667 MHz DDR2SDRAMI have put together a slideshow using photos that are animated by keyframe as well as a couple of compositions made in After Effects.
In Premier the animations look smooth.I rendered the video out using:
– Format: H.264
– Preset: HDTV 1080p 29.97
– NTSCWhen I viewed it in my Quicktime player the animations of the photos were choppy, but the compositions from After Effects rendered fine.
I opened a new Premier file and imported the video I had rendered to see if it was my Quicktime player causing the issue, but it appears choppy when viewed in Premier.What can I do to render a video with an aspect ratio of 1920 X 1080. The file format doesn’t matter. Would it work if I exported images and used another program to render.
I thought my computer would have the power to render out a slide show (I’ve exported lots of slideshows from iphoto in the past).
Thank you
