choppy playback when cropped
Hi all,
I’m working on a project where I have text over my footage and slugs being used as crops. All sources play back fine in the timeline (when rendered), and they play back fine when I export.I have two clips that are causing me grief. I’m playing these clip in the timeline (animation compression 720×486 at 23.98 fps) with no other layers active, and it plays back fine. I can export the clip with quicktime conversion and it plays back just fine in quicktime as well.
When I add text to a layer above the clip, or even just crop the clip with no other layers on, that clip’s playback is choppy after rendering as well as after exporting with quicktime conversion. It’s as if it’s adding pulldown (repeating frames) or some such. All else is the same (format, fps, etc).
Final Cut Pro 7.0.3.
I’m sure there’s something simple I”m missing.Thanks!
Jesse
