Activity › Forums › Adobe Premiere Pro › Choppy playback on Premiere Pro cc2015 from Iphone
  • Choppy playback on Premiere Pro cc2015 from Iphone
    Posted by Dougie Campbell on March 1, 2016 at 12:13 pm
    The quality looks fine on the Iphone 6s with no jerk at all. Then when it’s imported onto the PC either play in Premiere it’s slightly jerky.
    This is only really noticeable on a horizontal or vertical pan.
    I’m guessing it might be a codec issue and ,if so, what should I go for?
    Chris Wright replied 10 years, 6 months ago 3 Members · 5 Replies
  • Chris Evans
    March 1, 2016 at 3:16 pm
    Is is jerky because playback isn’t smooth? Try lowering the quality in the bottom of the preview window. Is it jerky because the footage somehow looks different? Try checking your interpret footage settings and sequence settings.
    I can’t really help more unless I know why it’s jerky. Got any more details?
  • Dougie Campbell
    March 1, 2016 at 3:55 pm
    Chris it’s only jerky on panning landscape or horizontal. It is jerky also when played outside of premiere pro by windows media player etc.
    When played on iphone or airshared on TV it plays without any issues.
    When I right click on the file it displays at 1920/1080 29 frames per second.
  • Chris Evans
    March 2, 2016 at 7:33 pm
    Where did you get this footage? I’d just transcode it and see if that helps. Whatever codec you want.
  • Dougie Campbell
    March 2, 2016 at 7:55 pm
    Took it on the iphone 6s. What should I transcode it to though?
  • Chris Wright
    March 4, 2016 at 5:47 pm
    its probably that variable framerate stuff that adobe can’t read.
    I recommend using handbrake to encode as quicktime png so you won’t lose any quality.
