Activity Forums Apple Final Cut Pro Legacy Choppy playback of 24P
  • Choppy playback of 24P
    Posted by Kieran Heilbron on June 11, 2009 at 5:14 pm
    Hello, been trying to find an answer to this for some time now so thought I’d try here:
    I shoot with a Canon XH A1S. When I edit 24F or 30F footage in Final Cut, after about 5-10 minutes (sometimes shorter, sometimes longer) the playback becomes choppy. Simply closing and re-opening the project in FCP solves this, but it’s really become quite a hassle. This does not happen with 60i footage. I am capturing as HDV, and editing in a 23.98 timebase.
    I can’t imagine that anything is wrong with my system, since playback is fine initially, and is fine again when I re-open the project. However, here’s what I’m using.
    I-Mac 2.4Ghz
    4GB RAM
    1TB G-Drive (scratch disk)
    1TB LaCie BigDisk (scratch disk)
    I save waveform cache, thumbnail cache and autosaves to my internal HD, which has plenty of free space.
    Any help is greatly appreciated.
    – Kieran
    John Fishback
    replied 17 years, 2 months ago
    2 Members · 3 Replies
  • John Fishback
    June 11, 2009 at 8:58 pm
    Have you trashed prefs and repaired permissions? If not, do that first and see if it helps. Also run Disk Warrior. If you don’t have it, you should get it. It keeps your system disk healthy.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Kieran Heilbron
    June 11, 2009 at 11:05 pm
    How do I get rid of preferences and permissions? You mean my Final Cut preferences?
    – Kieran
  • John Fishback
    June 12, 2009 at 2:05 pm
    Yes, FCP prefs. Here’s a Cow tutorial on the subject.
    https://library.creativecow.net/articles/harrington_richard/final_cut_trashing_preferences.php
    John
