Activity Forums Compression Techniques choppy motion on video
  • choppy motion on video
    Posted by Chris Larsen on September 8, 2008 at 11:36 pm
    I’m using Apple’s compressor to export mpeg-2, and the video looks like the odd and even fields are reversed. I’ve tried changing field dominance and video frame controls, but nothing has worked. Any suggestions.
    Specifics
    Mpeg-2 6.2 mbps max 7.7, 2 pass vbr best
    field dominance progressive, top, bottom (all look the same)
    Daniel Low replied 18 years ago 2 Members · 3 Replies
  • Daniel Low
    September 9, 2008 at 9:25 am
    What is your source?
    Are you resizing?
    Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free!
  • Chris Larsen
    September 10, 2008 at 7:38 pm
    i have gone into the resizing menu, only to toy with interlacing options, the source is standard 4:3 dv. the dimensions all stay the same
  • Daniel Low
    September 10, 2008 at 9:26 pm
    Just to be clear:
    Are you certain the source is interlaced?
    Are you wanting to deliver an interlaced or progressive output? (Or are you not concerned as long as it looks OK?)
    If progressive have you applied any deinterlacing?
    Any chance of posting a screenshot of the ‘effect’ somewhere?
