Activity Forums Apple Final Cut Pro Legacy Choppy Motion Graphics
  • Choppy Motion Graphics
    Posted by Eric Feller on February 13, 2007 at 3:09 pm
    Ever since I upgraded to FCP 5 I’ve had difficulty with motion graphics. Any resizing of still images or movement of graphic elements appear choppy/jittery once rendered. This is especially true if I try to composite a Livetype file over a still image. Any ideas…this is killing me.
    Eric Feller replied 19 years, 7 months ago 3 Members · 4 Replies
  • Eric Feller
    February 13, 2007 at 6:03 pm
    These jumps occur on all monitors (broadcast and otherwise). This is a new problem since upgrading to FCP 5. I can see these glitches even on the computer screen…not sure it’s a function of a low-res monitor. Been using my setup for 7 years with smooth results until now. And actually…if I play it out in preview mode, it seems to run smoother than when it is rendered or exported.
  • Mark Maness
    February 13, 2007 at 10:53 pm
    Two things…
    1. Trash your prefs.
    2. What Easy Setup are you using and what are your doing exactly?
    Once we find out this info, we can help you better.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
  • Bret Williams
    February 14, 2007 at 8:00 am
    FCP 5 completely changed the way it renders motion graphics. In the sequence settings you’ll see there are now 3 rendering settings. Try different settings. I know version 5.0 had some pretty big bugs in this area and I still run into it once in awhile. Exactly what you describe. Sometimes the best setting is horrible. Sometimes nesting screws the whole concept off. Usually I just keep everything on the middle setting.
  • Eric Feller
    February 14, 2007 at 3:02 pm
    Easy setup for DV-NTSC
    Doing basic key framed motion. Mostly slowly growing still images and moving objects across the screen. The problem occurs most when I have a basic text layer or Livetype layer superimposed on top of a still image background that is slowly growing or shrinking. But also occurs with no additional layers superimposed.
