Activity Forums Adobe After Effects Choosing X and Y path points separately
  • Choosing X and Y path points separately
    Posted by Scottie Tooley on January 7, 2011 at 9:55 am
    For my comp, I’ve set up a huge map, and I use a camera to zoom around the map at a perpendicular angle. I’ve turned off “auto-orient”.
    Sometimes I want a linear point, and sometimes a bezier. Once I’ve animated the camera, I go in the viewfinder so that I can see the points on the line. Problem is that I can only select the point for the X coordinate, and not the Y because they are right on top of each other.
    How do I select both?
    Scottie Tooley replied 15 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
