Activity Forums Adobe Premiere Pro Choosing right presets for TV
  • Choosing right presets for TV
    Posted by Carlos Angeli on May 13, 2010 at 5:20 pm
    Hi. Im´s stuck with the following:
    – I´ve got a movie trailer, that I need to play on a 42″ LCD TV that has a 1366 x 768 px resolution. Don´t know much about presets and resolution in video so please bare with me.
    So far, I´ve gotten a cropped image. Quality looks fine. It´s just that cropping that is bothering me.Aspect ratio is fine too. Just that the image is bigger than the screen, hence the cropping.
    Steps:
    I edited it in Premiere, and sent it to Encore for authoring the dvd through the dynamic link (or something like it).
    The trailer goes in a small window. The rest of the screen has some info and a wallpaper as background, so the whole space is used.
    -I designed the wallpaper in Photohop in the same resolution (1366 x 768px) imported to a Premiere sequence and sent to Encore. Aspect ratio is set to square pixels.
    I believe the problem is on the sequence settings. I tried using the widescreen presets, and the desktop mode to set the resolution exactly to 1366 x 768. However when sending to encore it won´t keep the same size. I have to choose between NTSC or PAL and I get the black bars on the preview.
    Another approach was in Premiere, taking the sequence and inserting it in a another one (using a 720 x 480 widescreen preset) and then sending it to Encore. This time I got rid of the bars but I get this cropping
    I can´t seem to find the correct way/ preset for displaying it properly on the TV.
    Any enlightenment on this would be really appreciated. Thanks
    Carlos Angeli replied 16 years, 3 months ago 3 Members · 3 Replies
  • Ann Bens
    May 13, 2010 at 8:44 pm
    What is the resolution of the movie trailer and what is the framerate?
    Are you in Pal land or Ntsc land?
    Is the movie trailer going to be play from a dvd or a BlyRay or …
  • Jeff Brown
    May 14, 2010 at 12:29 pm
    Ann has pointed the right direction:
    It does not matter what the monitor resolution is. What is the PLAYBACK DEVICE? That is what determines mastering resolution.
    -Jeff
  • Carlos Angeli
    June 2, 2010 at 11:50 am
    Hi Ann. Thanks for answering. My account took a long time to get activated and I couldn´t use it until now.
    -The trailer is played in a 42″ LCD TV that has a 1366 x 768 px resolution, from a DVD player.
    -I get a trailer on a DVD (vob). From then I go into Premiere import as an asset, and put inside a new sequence, let´s say sequence 1.
    Then create another sequence (2) that has an original background design (psd file) and put sequence 1 in it´s timeline, since I need the trailer to be displayed in a smaller part of the screen while still showing the psd behind it.
    Sequence 2 had the same resolution than the TV (1366 x 768) but then created one last sequence (DVPAL widescreen preset) and scaled down the previous one (2).
    That seems to have worked at least for fitting in the screen though I´m not sure about the quality. I have only seen it in my computer and the quality is not as good as I would like it to be.
    I´m in PAL land.
