Activity › Forums › Apple Final Cut Pro Legacy › Choosing perfect sequence setting for the documentary
  • Shane Ross
    June 2, 2010 at 8:04 pm
    [John Pale] “Or you can just edit on Avid Media Composer 4 or 5 and not worry about mixing anything.
    Not trying to be snarky. Its just the truth until the next FCS, anyway.”
    Yeah…that’s true. AVID MC4 and MC5 do mixed frame rates well.
    Shane
  • Shane Ross
    June 2, 2010 at 8:28 pm
    [Bret Williams] ” still can’t understand why not edit in an xdcam sequence, but with the rendering set to prores”
    Because the RENDERING TO PRORES only works with HDV and XDCAM footage. All the other footage in the timeline will render to ProRes, and that will a) look like crap, and b) cause the computer to crash…often. Been there, done that. Not pretty.
    Shane
  • Victor Goretsky
    June 2, 2010 at 9:32 pm
    Well, my home version of Avid is 3.05. Sure when you convert everything on the import to whatever rez your drives will allow – you will get “homogeneous” editing environment. Which is the same as you actually achive through prores.
  • John Pale
    June 2, 2010 at 10:09 pm
    If you upgrade to avid v4 or v5 you can mix and match pretty much anything you can throw at it without transcoding to a common format. It is not the same thing as FCP or earlier versions of MC.
Page 2 of 2
