Activity › Forums › Adobe Premiere Pro › Choosing a Single Audio Track for Multicam Use
  • Choosing a Single Audio Track for Multicam Use
    Posted by Ryan Dawson on May 18, 2014 at 5:50 pm
    Hello all, I am attempting to teach myself Premiere after being brought up in MC6-7. I shot a series of short interviews for a friend at an event using 2 cameras, a 650D and an XF105. I’m attempting to merge the 2 camera angles of each interview into multicam clips and then be able to cut back and forth between shots. The problem I’m having is that 1 of the audio sources was particularly bad and I’d rather not use it. When nesting the two sequences together, I grabbed only the video from the camera with the bad audio and now, when cutting from angle to angle in the clip, whenever I cut to the camera angle the had the bad audio, there is no audio. I assumed when splicing the 2 that the audio from the good cam would would become the primary and I’d be able to work from there. Any help would be appreciated.
    Bruce Klein replied 12 years, 4 months ago 2 Members · 1 Reply
  • Bruce Klein
    May 19, 2014 at 2:40 pm
    My work around, which may be incorrect, is that after I have set up the multicam time line, I go back and copy the audio I want to use and paste it into the multicam line. Then I lock it up and roll. It will add a new soundtrack as you edit. You can choose not to use it by shutting it off when you completed the edit.
    Hope this help
    I use Adobe Premiere Pro CS 5.5 on a IMAC 27, Intel core i5 2.7 GHz, 12 GB 1333 MHz DDR3… MAC OSX 10.6.8 I have a 2 2 Terabyte external drives also.
    Thanks in advance for your help.
    Bruce
