Activity › Forums › Adobe Premiere Pro › Choosing a Rendering Workstation
  • Choosing a Rendering Workstation
    Posted by Tom Black on March 4, 2017 at 11:57 am
    Hi
    We want to choose between a Workstation and a Server for the purpose of rendering quickly with Premiere Pro.
    The Workstation is HP Z600
    Xeon E5606 (8 Physical CPU)
    12 Gig RAM
    nVidia Quadro FX 4800
    (this workstation has the option of adding 2 graphics card)
    The Server is HP Prolient dl380 G7
    Xeon X5690 (12 Physical CPU)
    32 Gig RAM
    The Xeon X5690 cpu is more powerful than Xeon E5606
    If we decide to go with the Server, we will dedicate the server completely to the rendering job.
    what is the best option?
    Tom Black replied 9 years, 6 months ago 2 Members · 2 Replies
  • Alex Udell
    March 4, 2017 at 3:59 pm
    If you are considering dedicating a server for final rendering….
    this means likely you’d be rendering through Adobe Media Encoder, yes?
    remember that AME essentially opens a headless (no interface) version of PPro in the background to
    submit the jobs to render. So the things that benefit PPro will benefit the server as well
    1) Does the server have the option of adding a GPU to the cofiguration?
    GPU is a big part of Mercury and can speed up rendering significantly.
    2) Can the server have access to your editing system’s render previews via some sort of network configuration?
    if so, enabling the reuse of any previews (assume they are full quality) can potentially speed things up considerably too.
    3) RAM. Cheap part of a server config. Add it.
    4) Remember to keep fonts and plug-ins in sync with your editing configuration to avoid potential problems with output not matching what you saw in edit.
    hth
    Alex Udell
    Editing, Motion Graphics, and Visual FX
    Let’s Connect on Linkedin
    Examples: Retail Automotive Motion Graphics Spots
    Example: Customer Facing Explainer Video
    Example: Infotainment & Package editorial
  • Tom Black
    March 5, 2017 at 9:49 am
    Thank you very much
    specially for this
