Activity Forums Adobe After Effects choking a matte layer
  • choking a matte layer
    Posted by Elin Grome on March 18, 2010 at 5:59 pm
    Hi guys,
    I have a black and white layer which i am using as a luma matte…
    the problem is that there’s a bit of the background showing through so i would like to choke the matte a little bit; ie eat into the white area a little with 2-3 black pixels…
    but because this is a luma matte the simple choke doesnt work – it only works on alpha areas…
    can anyone help? 🙁
    thanks in advance
    Elin
    It’s all the those pesky details :p
    Elin Grome replied 16 years, 5 months ago 3 Members · 3 Replies
  • Samuel Hall
    March 18, 2010 at 6:13 pm
    I don’t have AE in front of me right at this moment so forgive me if this doesn’t work:
    You could try pre-composing the layer and it’s luma matte and apply a matte choke to the new pre-comped layer.
    Samuel Hall
    DP/Editor/VFX/Music
    http://www.vimeo.com/samhall
  • Darby Edelen
    March 19, 2010 at 8:33 am
    You can apply a Channels > Set Matte effect to the black/white matte and set it to use it’s own luminance as a matte, then apply the Matte > Simple Choker effect and use this layer as an alpha matte.
    The alternative is using Channels > Minimax applied to the black/white matte set to a Minimum operation with a radius of 1 or 2. However, if there are subtle details in the black/white matte then this can end up chunkifying those.
    These two different methods will have two different results, so try ’em both and see which works better.
    Darby Edelen
  • Elin Grome
    March 19, 2010 at 11:08 am
    Darby – your first solution worked fine – but thanks guys, all interesting techniques…
    Elin
