Activity Forums Adobe After Effects Choke effect on an image
  • Choke effect on an image
    Posted by Danielle Masek on November 16, 2011 at 5:42 am
    I’m trying to take an imported silhouette and have its edges sort of go in on itself. Please see attached photo. How do I do this? I’ve tried choke but nothing happens.
    **I look down at where you’re standing
    Flock of sheep all on display
    With all your lies piled up around you
    I can take it all away**
    Danielle Masek replied 14 years, 9 months ago 3 Members · 3 Replies
  • Brian Charles
    November 16, 2011 at 3:53 pm
    You may be able to use the MiniMax filter set to Minimum and then ad a blur to it.
  • Roland R. kahlenberg
    November 16, 2011 at 4:08 pm
    By ‘choke’ I am assuming that you are alluding to Matte Choker or Simple Choker. These require a non-full screen alpha channel. If your image doesn’t have an alpha channel, then you can create one using Shift Channels. I suggest that you search the COW for previous posts on how to create mattes from one of the color channels.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Danielle Masek
    November 16, 2011 at 11:06 pm
    Well choke seemed like the best way to describe what I’m trying to do. It may not be right. If you can picture the image I posted as the full silhouette of a man w/out any fx. Then it transforms into that pic, which looks like the edges moving inward to me. If that’s not what it is let me know what it is.
